In modern realities, possession of cryptocurrency does not provide privacy. The Bitcoin public ledger is absolutely transparent, and every operation leaves a history. Exchanges and exchange services use AML tools to analyze the purity of coins. If your funds have a "dirty" tag (Darknet, mixers, casinos, or P2P without KYC), you risk catching an wallet block until clarification. Therefore, the question of how to make Bitcoin clean is a measure of elementary hygiene for your wallet. There are two primary approaches to solving this task: applying anonymous coins or mixing services.
One option is converting Bitcoin into privacy coins like Monero (XMR) or Zcash (ZEC). These networks employ special encryption protocols that break the link about the source. The scheme is as follows: you exchange BTC for XMR, move XMR to a clean address, and then convert it again into clean Bitcoin. This method works, but has a number of complexities. First of all, it is time-consuming and technically complex. Furthermore, major platforms delist anonymous coins or require rigorous KYC upon their deposit, flagging them suspicious. As a result, by trying to conceal traces, you risk draw unnecessary attention from the AML officers.
The alternative is crypto mixers. These are specialized services that enable you to launder cryptocurrency directly, while operating within the Bitcoin network. Mixers accept funds from hundreds of different users, split them into pieces, mix them with their pool, and distribute them to clients as already clean coins to new addresses. How come is this secure? The fact is that the mathematical probability of tracing such a transaction is minimal. If you haven't stolen a billion dollars from the intelligence agencies and a whole department of the NSA with supercomputers isn't tracking you, then these services ensure practically 100% protection. For the average user, this is the simplest and most effective method to whiten capital. Further we present a list of 6 verified services.
Rating of the reliable platforms for anonymizing cryptocurrency
Mixitum — https://mixitum.top/?r=wuD7h9 — The best combination of performance and low commission, the suited for beginners.
ZeusMix — https://zeusmix.net/?ref=Zx19Qa — Advanced algorithm for mixing with an emphasis on a high level of obfuscating traces.
Whirto — https://whirto.com/?aff=WhR8k2 — A mixer with a intuitive design and a guarantee of No-logs.
Bmix — https://bmix.org/?partner=bM5uP0 — A Old and reliable tumbler with flexible settings for transaction delays.
ThorMixer — https://thormixer.com/?invite=Th0R7x — Maximum privacy thanks to special algorithms of cleansing.
UniJoin — https://anonymix.org/?code=An9Yw3 — A well-known service using the use of CoinJoin.
Mixitum This service is justifiably considered the best choice for those who for the first time wanted to launder crypto. Its key advantage is an intelligent algorithm of randomization, which independently selects a transaction strategy, relieving the user from the necessity to understand technical details. The service fee here is dynamic, which provides an extra level of protection, as it is more difficult for analysts to calculate the transfer based on mathematical patterns. The procedure takes a few minutes, and the system promises that all logs will be destroyed automatically after 24 hours, which excludes the risk of deanonymization in the future.
ZeusMix For those seeking uncompromising privacy, this mixer provides functionality of the highest class. At the heart of the system are proprietary methods of obfuscation that create a complex web of transfers, making the search of the sender unrealistic for most AML scanners. The client gets full control over the process: one can choose a quick mix for speed or an deep mixing for paranoid-level protection. 24/7 support is always available to sort out any questions, which turns using ZeusMix into a reliable and predictable process even for large investors.
Whirto Whirto is the example of simplicity and effectiveness in the sphere of privacy. The developers placed their bet on an clear interface so that every user could understand, how to make crypto clean, right away. The main trump card of Whirto is its strict No-Logs principle: the system do not record IP addresses and order details, erasing everything upon completion of the transaction. Additionally implemented is a function of temporal delay, which enables you to receive clean coins not instantly, but after a set interval, which finally disrupts the link between your input and output.
Bmix When it comes to operations with significant volumes, the Bmix service holds a leading position thanks to its high liquidity. The essence is that you do not need to wait for other users to deposit their funds for mixing — the transfer proceeds from the reserve fund of the platform. For the assurance of its clients, Bmix provides a cryptographic Letter of Guarantee, which serves as proof of the deal. Another important function is the special code: by entering it during the next order, you ensure that the system will not return you your own previously sent coins, which ensures a perfect history.
ThorMixer Named after the Norse god, this service offers impenetrable armor against any kind of surveillance. The platform is optimized for working via the Tor browser, which masks the even the attempt of accessing the mixer. The uniqueness of ThorMixer's method lies in the intelligent splitting of outbound transactions: the money arrive to your wallet not in a single piece, but as a series of different transfers from different addresses and at in a chaotic order. Such an method makes attempts at analysis into a meaningless endeavor, as it is simply impossible to assemble the puzzle back.
UniJoin UniJoin stands out from its peers thanks to its use of the advanced technology CoinJoin. Instead of traditional mixers, in this case a joint formation of a transfer is implemented: the funds of multiple users are combined into a unified stream before sending. This method provides a technical guarantee that one cannot determine whose coin corresponds to which recipient. The service is ideally suited for those who want to have a maximally clean history for their wallet and to stop worrying about claims from exchanges.
Conclusion and recommendations
By using these services, you acquire independence from the all-seeing eye of the blockchain. But keep in mind the safety rules: always access via Tor or a VPN, split large amounts and make use of the delay function. Cleansing Bitcoin is not criminal, but a way to preserve your property in a transparent world.
How to make crypto clean: Working methods of anonymization and a rating of mixers for this year
StanleyLaupe
- Junior
