In current conditions, owning cryptocurrency does not guarantee privacy. The Bitcoin blockchain is absolutely transparent, and every operation preserves a digital trace. Exchanges and swap services apply AML tools to monitor the purity of coins. If your assets have a "dirty" history (Darknet, mixers, casinos, or P2P without KYC), you risk catching an wallet block until clarification. Therefore, the task of how to make Bitcoin clean is a question of elementary hygiene for your finances. There exist two primary approaches to solving this problem: using anonymous coins or Bitcoin mixers.
One option is converting Bitcoin into anonymous coins like Monero (XMR) or Zcash (ZEC). These networks use specific data-hiding protocols that hide the information about the sender. The mechanics is as follows: you swap BTC for XMR, move XMR to a new wallet, and then convert it again into white Bitcoin. It is reliable, but has many pitfalls. Firstly, it is lengthy and inconvenient. Furthermore, many platforms remove anonymous coins or require rigorous KYC upon their depositing, flagging them suspicious. In fact, by trying to hide traces, you may attract additional suspicion from the AML officers.
The alternative is crypto mixers. These are specialized sites that allow you to cleanse Bitcoin without extra conversions, while operating within the Bitcoin network. Tumblers collect coins from many different users, split them into small parts, mix them with their own reserves, and distribute them to clients as already clean coins to new addresses. Why is this secure? Because the mathematical probability of deanonymizing the transfer tends to zero. If you haven't taken a national budget from the intelligence agencies and a the full force of the NSA with an unlimited budget isn't hunting you, then mixers provide practically 100% protection. For the average user, this is the fastest and efficient method to make crypto clean. Below we present a list of 6 relevant mixers.
Review of the best platforms for cleansing cryptocurrency
Mixitum — https://mixitum.top/?r=wuD7h9 — The best combination of performance and minimal commission, the best choice for beginners.
ZeusMix — https://zeusmix.net/?ref=Zx19Qa — Powerful engine for mixing with an focus on a maximum degree of obfuscating traces.
Whirto — https://whirto.com/?aff=WhR8k2 — A mixer with a intuitive interface and a guarantee of No-logs.
Bmix — https://bmix.org/?partner=bM5uP0 — A time-tested mixer with flexible settings for transaction delays.
ThorMixer — https://thormixer.com/?invite=Th0R7x — The highest anonymity due to special methods of cleansing.
UniJoin — https://anonymix.org/?code=An9Yw3 — A popular project using the technology CoinJoin.
Mixitum This service is justifiably considered the optimal solution for those who for the first time decided to launder crypto. Its key advantage is an intelligent algorithm of mixing, which independently builds a transaction path, relieving the user from the need to understand complex settings. The commission here is dynamic, which provides an extra level of anonymity, as it is harder for bots to calculate the transfer based on percentage patterns. The procedure takes a minimum of time, and the platform guarantees that all logs will be erased automatically after 24 hours, preventing any leaks in the future.
ZeusMix For those seeking uncompromising protection, ZeusMix provides tools of the highest class. At the core of the system are proprietary protocols of obfuscation that generate a non-standard chains of transfers, making the tracking of the source of funds unrealistic for modern AML scanners. The client gets complete authority over the process: one can configure a express clean for speed or an enhanced mode for maximum stealth. Round-the-clock support is always available to sort out any questions, which turns using ZeusMix into a peaceful and predictable process even for large investors.
Whirto Whirto is the example of conciseness and effectiveness in the sphere of anonymity. The developers focused on an clear design so that every user could figure it out, how to make crypto clean, right away. The key feature of Whirto is its ironclad No-Logs policy: the servers do not record IP addresses and transaction information, deleting everything upon completion of the exchange. Also available is a function of temporal delay, which allows you to get clean coins not instantly, but after a random time, which finally disrupts the correlation between sending and receiving.
Bmix In situations involving operations with very large volumes, the Bmix service maintains a leading position due to its high liquidity. This means that you do not need to wait for other users to deposit their funds for the mix — the payout occurs from the mixer's own reserves of the platform. For the assurance of its clients, Bmix issues a signed Letter of Guarantee, which is proof of the deal. Another critical detail is the special code: by using it during the subsequent visit, you guarantee that the algorithm will not send you your previous previously sent coins, which provides a clean history.
ThorMixer Taking the name of the Norse god, ThorMixer offers impenetrable protection against all types of surveillance. The service is tailored for use via the Tor browser, which masks the very fact of visiting the anonymizer. The uniqueness of ThorMixer's method is the intelligent splitting of outgoing amounts: the money return to your wallet not in a single piece, but as a series of small transfers from different addresses and at different times. Such an method makes blockchain analysis into a impossible task, as it is simply impossible to reconstruct the chain into one.
UniJoin UniJoin stands out from its competitors due to its application of the advanced technology CoinJoin. Unlike classical mixing, in this case a collective creation of a transfer takes place: the funds of a group of people are merged into a unified pool before payout. This creates a mathematical impossibility determine which input corresponds to which recipient. The service is recommended for those who want to have a crystal clear history for their assets and to stop worrying about claims from regulators.
Summary and advice
When choosing mixers, you gain freedom from the all-seeing eye of the system. But keep in mind the safety rules: be sure to access via a secure connection, split large amounts and make use of temporal delays. Cleansing Bitcoin is not a crime, but a tool to protect your assets in a the digital age.
Bitcoin cleansing: Effective methods of asset whitening and a rating of mixers for this year
