In modern realities, possession of cryptocurrency does not guarantee privacy. The Bitcoin public ledger is absolutely transparent, and every transaction leaves a history. Trading platforms and exchange services use AML tools to analyze the purity of coins. If your funds have a "dirty" tag (Darknet, mixers, casinos, or P2P without KYC), there is a risk of getting an wallet block until clarification. Therefore, the task of how to launder crypto is a question of basic hygiene for your wallet. There are two primary ways to solving this task: applying privacy coins or Bitcoin mixers.
The first method is converting BTC into anonymous coins like Monero (XMR) or Zcash (ZEC). These networks employ specific encryption technologies that hide the link about the sender. The scheme looks like this: you swap BTC for XMR, transfer XMR to a new wallet, and then swap it again into white Bitcoin. This method works, but has many pitfalls. First of all, it is time-consuming and inconvenient. Furthermore, many exchanges delist anonymous coins or require strict KYC upon their deposit, flagging them suspicious. As a result, by trying to conceal transactions, you may draw additional attention from the security service.
The second method is Bitcoin mixers. These are specialized sites that allow you to cleanse cryptocurrency directly, while remaining within the Bitcoin blockchain. Mixers collect funds from many clients, split them into pieces, tumble them with their own reserves, and send them back as new coins to clean wallets. Why is this reliable? The fact is that the chance of tracing the transfer tends to zero. If you haven't taken a national budget from the Pentagon and a the full force of the NSA with supercomputers isn't tracking you, then mixers ensure practically 100% protection. For the average user, this is the fastest and most effective method to whiten capital. Further we present a list of 6 verified services.
Review of the reliable platforms for anonymizing BTC
Mixitum — https://mixitum.top/?r=wuD7h9 — Ideal combination of speed and minimal fee, the best choice for starting out.
ZeusMix — https://zeusmix.net/?ref=Zx19Qa — Advanced engine for tumbling with an focus on a maximum degree of anonymization.
Whirto — https://whirto.com/?aff=WhR8k2 — A service with a intuitive interface and a policy of no logs.
Bmix — https://bmix.org/?partner=bM5uP0 — A Authoritative mixer with convenient settings for transaction delays.
ThorMixer — https://thormixer.com/?invite=Th0R7x — The highest privacy thanks to unique algorithms of mixing.
UniJoin — https://anonymix.org/?code=An9Yw3 — A popular project using the use of CoinJoin.
Mixitum Mixitum is rightfully considered the best choice for beginners who decided to launder crypto. Its key advantage is an intelligent algorithm of randomization, which automatically builds a transaction strategy, relieving the user from the necessity to delve into complex settings. The service fee here is not fixed, which adds an extra level of anonymity, as it is harder for bots to calculate the transfer based on mathematical patterns. The entire process takes a few minutes, and the system guarantees that digital traces will be destroyed irrevocably after 24 hours, preventing the risk of deanonymization in the future.
ZeusMix If you are looking for total protection, ZeusMix provides functionality of professional grade. At the core of the system are proprietary methods of confusion that create a complex web of transactions, turning the tracking of the source of funds unrealistic for most AML scanners. The user has full control over the process: one can configure a quick mix for efficiency or an deep mixing for maximum stealth. Round-the-clock help service is always available to resolve issues, which turns using ZeusMix into a reliable and predictable process even for significant amounts.
Whirto Whirto is the embodiment of conciseness and reliability in the niche of anonymity. The developers focused on an clear interface so that every user could figure it out, how to make crypto clean, right away. The key feature of Whirto is its strict No-Logs principle: the servers do not record IP addresses and order details, erasing everything upon execution of the exchange. Additionally available is a function of delayed payout, which allows you to get clean coins not instantly, but after a random time, which finally disrupts the correlation between sending and receiving.
Bmix When it comes to working with very large amounts, the Bmix service holds a leading position due to its huge reserves. This means that you do not need to wait for other users to add their funds for mixing — the transfer proceeds from the reserve fund of the platform. For the assurance of its users, Bmix provides a signed Letter of Guarantee, which is proof of the deal. Another critical function is the special code: by using it during the subsequent order, you guarantee that the system will not send you your previous old coins, which provides a perfect anonymity.
ThorMixer Named after the Thor, this service provides impenetrable armor against any kind of surveillance. The service is optimized for use via the onion networks, which masks the very fact of visiting the mixer. The distinctive feature of ThorMixer's approach is the fragmentation of outbound transactions: the clean funds return to the address not in one lump sum, but as multiple different transfers from different addresses and at different times. Such an approach turns attempts at analysis into a meaningless task, as it is simply impossible to reconstruct the chain into one.
UniJoin UniJoin stands apart from its peers due to its application of the advanced technology CoinJoin. Unlike traditional mixers, here a joint creation of a transfer is implemented: the coins of multiple users are merged into a unified pool before sending. This method provides a technical impossibility figure out whose coin corresponds to which output. The service is recommended for those wishing to obtain a maximally clean history for their wallet and to stop worrying about claims from regulators.
Conclusion and advice
By using these services, you acquire independence from the surveillance of the system. However remember the nuances: always use via Tor or a VPN, break down significant deposits and do not neglect the delay function. Cleansing Bitcoin is not criminal, but a tool to preserve your property in a the digital age.
How to make crypto clean: Effective ways of asset whitening and a rating of the best services for this year
