In modern realities, possession of cryptocurrency does not guarantee anonymity. The Bitcoin public ledger is absolutely open, and every operation preserves a history. Exchanges and exchange services use AML tools to analyze the provenance of coins. If your funds have a "dirty" tag (Darknet, mixers, casinos, or P2P without KYC), you risk getting an account ban indefinitely. Therefore, the task of how to launder crypto is a question of elementary hygiene for your finances. There are two primary ways to accomplishing this problem: using privacy coins or mixing services.
The first method is converting BTC into anonymous cryptocurrencies like Monero (XMR) or Zcash (ZEC). These blockchains employ special data-hiding protocols that break the information about the source. The mechanics looks like this: you exchange BTC for XMR, transfer XMR to a clean address, and then convert it back into clean Bitcoin. This method works, but has a number of complexities. Firstly, it is lengthy and inconvenient. Furthermore, major platforms remove anonymous coins or require rigorous KYC upon their depositing, flagging them risky. As a result, by trying to hide transactions, you may draw additional suspicion from the AML officers.
The second method is Bitcoin mixers. These are professional services that enable you to launder cryptocurrency without extra conversions, while operating within the Bitcoin network. Tumblers accept coins from hundreds of different users, split them into pieces, tumble them with their own reserves, and send them to clients as new coins to clean wallets. Why is this reliable? The fact is that the chance of tracing the transfer is minimal. If you haven't taken a national budget from the intelligence agencies and a whole department of the NSA with an unlimited budget isn't hunting you, then these services provide practically 100% guarantee. For the private investor, this is the fastest and most effective way to make crypto clean. Below we present a list of 6 verified services.
Rating of the best platforms for anonymizing cryptocurrency
Mixitum — https://mixitum.top/?r=wuD7h9 — The best combination of performance and minimal commission, the best choice for starting out.
ZeusMix — https://zeusmix.net/?ref=Zx19Qa — Advanced algorithm for tumbling with an focus on a high level of anonymization.
Whirto — https://whirto.com/?aff=WhR8k2 — A site with a intuitive interface and a guarantee of no logs.
Bmix — https://bmix.org/?partner=bM5uP0 — A Authoritative tumbler with flexible settings for transaction delays.
ThorMixer — https://thormixer.com/?invite=Th0R7x — The highest privacy thanks to unique methods of mixing.
UniJoin — https://anonymix.org/?code=An9Yw3 — A well-known service using the use of CoinJoin.
Mixitum Mixitum is rightfully considered the optimal solution for those who for the first time decided to clean Bitcoin. Its key advantage is an intelligent algorithm of mixing, which independently selects a transaction path, relieving the user from the necessity to delve into complex settings. The commission here is not fixed, which provides an extra level of protection, as it is harder for bots to find the exact amount based on mathematical patterns. The procedure lasts a few minutes, and the platform promises that digital traces will be destroyed irrevocably after 24 hours, which excludes any leaks in the future.
ZeusMix If you are looking for total privacy, ZeusMix offers functionality of the highest class. At the core of the service are unique protocols of confusion that create a complex web of transactions, turning the tracking of the source of funds impossible for most AML scanners. The client has full control over the process: one can configure a quick mix for efficiency or an enhanced mode for maximum stealth. 24/7 help service is ready to sort out any questions, which turns using ZeusMix into a peaceful and comfortable process even for significant amounts.
Whirto Whirto is the embodiment of simplicity and reliability in the sphere of privacy. The team placed their bet on an intuitive design so that every user could understand, how to make crypto clean, right away. The main trump card of Whirto is its ironclad No-Logs policy: the system do not record metadata and order details, deleting everything immediately after execution of the transaction. Additionally available is a option of delayed payout, which allows you to get clean coins not immediately, but after a random time, which completely breaks the link between sending and receiving.
Bmix In situations involving operations with significant volumes, the Bmix service holds a leading position thanks to its high liquidity. This means that you do not need to wait for other users to deposit their funds for mixing — the payout occurs from the mixer's own reserves of the platform. For the assurance of its users, Bmix issues a cryptographic Letter of Guarantee, which is proof of the deal. Another critical function is the mix-code: by using it during the next visit, you guarantee that the system will not send you your previous old bitcoins, which provides a perfect anonymity.
ThorMixer Taking the name of the Thor, ThorMixer provides powerful armor against all types of surveillance. The service is tailored for use via the Tor browser, which hides the very fact of visiting the anonymizer. The uniqueness of ThorMixer's method is the intelligent splitting of outbound amounts: the money arrive to your wallet not in one lump sum, but as multiple different transfers from various wallets and at different times. Such an approach turns attempts at analysis into a meaningless endeavor, as it is unrealistic to assemble the puzzle into one.
UniJoin UniJoin stands out from its competitors thanks to its use of the protocol CoinJoin. Instead of classical mixing, here a joint formation of a transaction is implemented: the coins of multiple users are combined into a unified stream before payout. This method provides a mathematical guarantee that one cannot determine whose coin belongs to which output. The service is ideally suited for those wishing to obtain a maximally clean history for their wallet and to stop worrying about questions from exchanges.
Summary and advice
When choosing mixers, you gain independence from the all-seeing eye of the blockchain. However keep in mind the safety rules: always access via a secure connection, break down significant deposits and make use of the delay function. How to launder crypto is not criminal, but a way to preserve your assets in a transparent world.
How to launder crypto: Working ways of anonymization and a rating of mixers for 2026
