Motor ne starta p080a
VladaR
Postovi: 1
Pridružio se: 22 Jul 2018 10:50
Post od VladaR » 22 Jul 2018 10:54
Zdravo svima,
Da li neko moze da mi kaze kako da nastelujem senzor za kuplung?
Uradio sam servis reset na Cruzu 1.8 benzin sa manuelnim menjacem i onda mi se pojavio feler P080A
da moram kuplung poziciju da ''naucim''
Hvala
dixy
Postovi: 59
Lokacija: Dobanovci, Surčin
Post od dixy » 23 Jul 2018 15:34
Re: Motor ne starta p080a
Zdravo Vlado,
Senzor položaja pedale kvačila nije moguće "naštelovati". Komanda za proceduru učenja položaja pedale može se zadati samo iz GM dijagnostičkog interfejsa, prevashodno GM MDI, tj Tech2. Prilikom servisiranja automobila otkačeno je nešto što je do te greške dovelo, pa proveri sve konektore.
Evo teksta iz GM servisnog priručnika:
"Clutch Pedal Position Sensor Learn
Note: The clutch pedal position (CPP) sensor learn procedure is required when the following service procedures have been performed regardless of whether DTC P080A is set:
• An engine control module (ECM) replacement
• A CPP sensor replacement
• Any repairs which affect the CPP sensor relationship
Install a scan tool.
Monitor the ECM for DTCs with a scan tool. If other DTCs are set, except DTC P080A, refer to Diagnostic Trouble Code (DTC) List - Vehicle for the applicable DTC that set.
With a scan tool, select Clutch Pedal Position Learn under engine control module (ECM) Configuration/Reset Functions, and perform the following instructions displayed on the scan tool screen.
Note: The CPP sensor learn procedure cannot be performed more than once per ignition cycle. The clutch pedal needs to be fully depressed and held steady throughout this procedure in order to perform a correct learning.
The scan tool will display under CPP Learn Status: Not Learned, In Process, Complete, Fail - Low Volt, Fail - High Volt, or Fail Moving. The scan tool will display under CPP Learn Status Learning Successful if the process was successful.
If the scan tool indicates that DTC P080A ran and passed this ignition cycle, the CPP sensor learn procedure is complete. If the scan tool indicates DTC P080A failed or did not run this ignition cycle, turn Ignition OFF and perform the learning procedure once again. If any other DTC is set, refer to Diagnostic Trouble Code (DTC) List - Vehicle for the applicable DTC.
Turn OFF the ignition for 30 s after the learn procedure has successfully completed in order to store the CPP sensor variation values in ECM history."
Izvor: http://www.autocats.ws/manual/chevrolet ... 22.en.html
Povratak na “5v novi”
