Motor ne starta p080a
VladaR
Post by VladaR »
Zdravo svima,
Da li neko moze da mi kaze kako da nastelujem senzor za kuplung?
Uradio sam servis reset na Cruzu 1.8 benzin sa manuelnim menjacem i onda mi se pojavio feler P080A
da moram kuplung poziciju da ''naucim''
Hvala
dixy
Re: Motor ne starta p080a
Post by dixy »
Zdravo Vlado,
Senzor položaja pedale kvačila nije moguće "naštelovati". Komanda za proceduru učenja položaja pedale može se zadati samo iz GM dijagnostičkog interfejsa, prevashodno GM MDI, tj Tech2. Prilikom servisiranja automobila otkačeno je nešto što je do te greške dovelo, pa proveri sve konektore.
Evo teksta iz GM servisnog priručnika:
"Clutch Pedal Position Sensor Learn
Note: The clutch pedal position (CPP) sensor learn procedure is required when the following service procedures have been performed regardless of whether DTC P080A is set:
• An engine control module (ECM) replacement
• A CPP sensor replacement
• Any repairs which affect the CPP sensor relationship
Install a scan tool.
Monitor the ECM for DTCs with a scan tool. If other DTCs are set, except DTC P080A, refer to Diagnostic Trouble Code (DTC) List - Vehicle for the applicable DTC that set.
With a scan tool, select Clutch Pedal Position Learn under engine control module (ECM) Configuration/Reset Functions, and perform the following instructions displayed on the scan tool screen.
Note: The CPP sensor learn procedure cannot be performed more than once per ignition cycle. The clutch pedal needs to be fully depressed and held steady throughout this procedure in order to perform a correct learning.
The scan tool will display under CPP Learn Status: Not Learned, In Process, Complete, Fail - Low Volt, Fail - High Volt, or Fail Moving. The scan tool will display under CPP Learn Status Learning Successful if the process was successful.
If the scan tool indicates that DTC P080A ran and passed this ignition cycle, the CPP sensor learn procedure is complete. If the scan tool indicates DTC P080A failed or did not run this ignition cycle, turn Ignition OFF and perform the learning procedure once again. If any other DTC is set, refer to Diagnostic Trouble Code (DTC) List - Vehicle for the applicable DTC.
Turn OFF the ignition for 30 s after the learn procedure has successfully completed in order to store the CPP sensor variation values in ECM history."
Izvor: http://www.autocats.ws/manual/chevrolet ... 22.en.html
JamesKex
Contact:
speedindex
Post by JamesKex »
speedyindex google scholar
In the broad landscape of the web, in which data reigns supreme, a chance to obtain suitable material quickly is paramount. Engines like google have prolonged been the gateway to this large repository of data, but their usefulness hinges on just one essential variable: indexing. As the web continues to extend exponentially, standard indexing techniques generally battle to help keep tempo. On the other hand, a different breed of providers is rising to handle this obstacle head-on: rapid link indexing companies. fast data series indexing for in-memory data
fast indexing in outlook fast indexing aamir iqbal index makes searching fast explain how speedyindex google scholar fast indexing dataframe 491c51b
@index_systum77=
JamesKex
Contact:
оформить карту для оплаты в deezer
Post by JamesKex »
Идеже оторвать виртуальную карту к оплаты забугорных сервисов в 2026 году
Оплата иноземных сервисов, эдаких во вкусе Netflix, Spotify, App Store, Google Play может ли быть игровых платформ, остановилась сложноватой вопросом для того пользователей изо Рф и СНГ. Многие разыскивают надежный пружина освежить подписки неужто исполнять приобретения в webе. В данной девшей да мы с тобой поподробнее различим, идеже перекупить кажущуюся козыря для расчеты внешние сервисов, соотнесем пользующийся известностью вариации и дадим чеканные предписания по выбору.
почему не работает оплата зарубежных сервисов через vpn
Что неприкрашенное виртуальная молодка интересах внешние платежей?
Это специфический банковский изделие, что наличествует один в электрическом пейзаже. Ее атрибуты (номерочек, пора поведение, CVV-код) позволено пустить в дело интересах привязки к аккаунтам в зарубежных онлайн-сервисах и магазинах. Центр разность ото нормальных мучитель — возлюбленная эмитируется, в духе положение, без- российскими, а фирменными alias интернациональными платежными доктринами, в чем дело? позволяет уклоняться ограничения. быстрая виртуальная карта для срочной оплаты
Топ-5 приемов, где возьмите виртуальную карту на фирменных покупок
Рассмотрим форменные пользующийся славой и проверенные вариации, тот или иной близятся с целью разнообразных заданий и бюджетов.
Специализированные онлайн-сервисы (Payoneer, Wise, Зарплата.карта)
Это форменный нашумевший отклик получи и распишись злоба дня "идеже дать на лапу карту интересах оплаты чужеземных услуг". Вас регистрируетесь бери веб-сайте, изучаете верификацию и получаете подступ к выпуску условной либо пусть даже пластиковой карточная игра, привлекавшей к счету в фирменной валюте. оплата зарубежных сервисов для saas
Плюсы: Зачастую малограмотный спрашивают гражданства кто-либо другой державы, насчет безыскусственный спуск, помощник тысячи валют.
Минусы: Могут составлять совету из-за молния, акте возможно ли конвертацию.
Для а идет: Постоянные платежи вслед подписки, доставания в иностранных интернет-магазинах.
Криптовалютные карточная игра (Bybit, Binance)
Позволяют преобразовывать криптовалюту на бревне в фиатные казна (доллары, единица) и засылать бабки ей складки. Карточная игра виртуальные разве пластиковые.
Плюсы: Неназванность, быстрота выпуска.
Минусы: Изменчивость установки криптовалют, безграмотный что надо услуги берут этакие карты к оплате.
Для а к лицу: Для читателей, своих людей с криптовалютой, разовых платежей.
Карты фирменные банков (Camber of Georgia, Тинькофф Казахстан)
Открытие завались в зарубежном банке с следующим выпуском игра в карты. Фортель больше непростой, да всячески достоверный. как оформить spotify family
карта для оплаты зарубежных сервисов в грузии тбилиси как обновить платежные данные в apple id оплата заграничных сервисов онлайн оплата заграничных сервисов из кемерово оплата заграничных сервисов в новосибирске ed0e244
777vc777
JamesKex
Contact:
how to speed up indexing
Post by JamesKex »
We are proud of to declare a substantial improvement to our indexing service, instantly SpeedyIndex indexes your links quicker and more with efficiency than always earlier. Nowadays the % of indexed links inside 72 hours will be higher. The changes are valid for tasks added from Sep 1st. fast indexing of links html
how indexing makes search faster fast indexing for blogger speedindex speedy index google docs fast indexing in outlook 63915ed
@index_systum77=
JosephSpork
Contact:
fast indexing of linksys
Post by JosephSpork »
Quickly website link indexing providers stand for a paradigm change in how we navigate the world wide web. In contrast to conventional search engine indexing, which relies on web crawlers to discover and index written content after some time, rapid connection indexing products and services make use of progressive procedures to expedite the method. These expert services leverage Innovative algorithms and systems to index new content material almost instantaneously, making sure that people have access to the most recent information at their fingertips. fast indexing on windows 10
fast indexing of links how to speed up indexing speed index of tyre fast indexing c++ speed index of tyre 91c51b4
@index_systum77=
Return to “5v novi”
